Under Arbortext Editor and with ACL language, I would like to activate a customized menu (grayed or not) depending on the context. For example, if the cursor of the mouse is in a specific tag, the customized menu is activated. If not, the menu is disabled (grayed).
We can use this function to active or not the menu:
function activeMenu() {
if (in_context("tagname") != 1) {
return 0;
return 1;
and use the command lines to add the menu:
menu_add -menu -before .Help 'TEST';
menu_add .TEST. "TEST1" -cmd { test() } \
-active "activeMenu() == 1";
Best regards
David G
return 0;
return 1;
Best regards
David G
