Hello everyone.
Is there any way to change the template file to my own template when opening IsoDraw?
Thank you for your help.
From "Help Center" - "Creating a Template File": https://support.ptc.com/help/isodraw/r7.4/en/index.html#page/isodraw_top_toc/Example_19_fnd.html
Hello @mschnurbus,
Thank you for using PTC Community.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
You might also find it useful to refer to the guide on how to ask a good question. This will enhance the likelihood of receiving valuable assistance from other Community members.
I hope this information is helpful.
Best Regards,
Vivek N
Community Moderation Team.
Hello mschnurbus,
It looks like you have some responses from our community champions. If it helped to answer your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
You can create template files following the instruction link that VladimirN provided. Once you save them in the template folder. They will be available from the file, new menu. I have asked before and there is no way for it to open your template file as the default. That would be nice.
Also you can now copy these templates to other users and have them use the same template files. It would also be nice if the template files could be stored in a referenced network location like the macros.
Bryon
