Is it possible to edit multiple ACM fragments as XML?
lfuellenbach
I have opened a document from ACM that includes several bursted objects or fragments. Selecting Edit > Edit Selection as XML Source results in:
<cards>
<xi:include href="x-wc://file=0000119577.xml" xmlns:xi="http://www.w3.org/2001/XInclude"><xi:fallback><!--Fallback markup for "x-wc://file=0000119577.xml"--></xi:fallback></xi:include>
<xi:include href="x-wc://file=0000119576.xml" xmlns:xi="http://www.w3.org/2001/XInclude"><xi:fallback><!--Fallback markup for "x-wc://file=0000119576.xml"--></xi:fallback></xi:include>
<xi:include href="x-wc://file=0000119575.xml" xmlns:xi="http://www.w3.org/2001/XInclude"><xi:fallback><!--Fallback markup for "x-wc://file=0000119575.xml"--></xi:fallback></xi:include>
</cards>
Typing "edit -current -untagged" in the Command line presents similar results. Is there a way to edit those fragments as XML?
Thank you,
Lisa
It is showing like that because the XIncluded content cannot be retrieved from Windchill. Are you sure those objects are available in Windchill? I think you can try opening the x-wc:// links directly once connected to Windchill. Maybe try an ACL command like: edit "x-wc://file=0000119577.xml" (haven't tested that out)
