Is there anyway to convert XLS-FO doc to PDF from command line?
Tusken_Raider
6-Contributor
As per this thread, similar issue:
This is an old question, but I am looking to do the same thing for batch publishing and testing my XSL-FO. If the OP has a way to do this, or anybody else knows a way to convert XSL-FO to PDF from the command line, their advice would be much appreciated.
Hello
Officially the FO option within Arbortext is no longer supported so it's a "use at your own risk feature" and will be superseded by a new ALD library based FO pagination option, we hear might be released in Q4-22+ (TBC).
Within editor you can create custom scripts to run external programs which could include FOP or for more feature rich flexibility I would suggest you also look at Antenna House Formatter, or of course wait until the new Arbortext FO option is released!
PM us if you would like more information about all these items.
Regards
www.tformat.com
PTC VARs
Just replied to referenced post 👍
