I have joined newly to this community,
we use to change the file/drawing name inside as well as outside for huge nos.of drawings in ISODRAW, could u pls help me how can i do it with help of macros in ISODRAW.
Hi @SH_8396062
I recommend giving more details and context about the problem you have in mind. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
FILE NAMEI have iso files named as above, i want to change the names in series due to adding some files in between. so 110 became 111.....so on. this how can i do it in isodraw macro, i want to do this name/ICN changes in inside as well as outside of each file.
With Isodraw open you can batch process files in a folder specifying a macro to use, but I am not sure if it can rename the original file name of the file. We have a macro that takes the name of the file and places it in the bottom right corner of the illustration.
I hope this helps
Bryon
Hello @SH_8396062,
It looks like you have a response from a community member. If it helped to solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
