Hi there:)
I'm Bell
I have a question
I want know remove all changmark in Dm
and I heard
someone removed successes through the Arbortext Styler!
but i can't find..... please help me🙏
If you are talking about standard Arbortext Editor change tracking, you can use the Accept/Reject Changes feature to clear them all at once (either reject all changes or accept all):
If you are using an S1000D implementation (which is indicated by your use of "DM" instead of "document" or "topic"), then you will probably need to check with the vendor of your S1000D solution. They may have some custom scripting to let you clear the changemark attributes in your document, or you may have a publishing option to hide the changebars in the output without modifying the markup. But that would depend on the specific S1000D implementation.
Hi @권권_11165447,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Hi @권권_11165447,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
