All,
Does anyone have a code sample to generate 'List of Effective pages' in Styler by editing APP resource?
I tired and could not get somewhere closer.
Does APP has something like FOSI SaveText/UseText?
Any help will be highly appreciated.
Rashmi Gaonkar
rashmigaonkar75@gmail.com
If your XML has sufficient details available then you can generate LEP with APP. This would require some Javascript scripting that uses the FOM APIs. This is quite an advanced feature so you may need help with this - here at GPSL we do this kind of work every day and have developers who can assist.
Thank you for guidelines. I will contact you once I have more details.
Rashmi
I agree with Gareth it is not strait forward... depending on your requirements and XML structure, if you want to piggy back on to Stylers TOC or create your own, amongst other things, it can be done in a number of different ways so might be best to consult directly with a partner/consultant on your specifics
Regards
