I use Leonardo plug in to create companion file. Can anyone provide me the exact procedure to do this?
Could you provide more information and give an example of what you want?
Well, i need to create intelligent graphics for one of our customer using there styleguide. It involves creating the object info and hotspots to graphic element and also need to generate companion file (.cmp), which is an XML coding of graphics. This companion file is used in Ultraxml to communicate/hyperlink/interact with procedure.
Ex: All the callouts of a graphics should be interactive with the authoring part whereever these callouts are referred in procedure.
