Missing DCF Arbortext files for DITA v2.0
DG_9924912
The Arbortext Editor 8.2.3 download is missing some DCF files for DITA v2.0.
Where can I download files for:
doctypes\dita\2.0\bookmap\dita20-base-module.dcf
doctypes\dita\2.0\bookmap\dita-map-module.dcf
doctypes\dita\2.0\bookmap\dita20-map-module.dcf
I was getting an error because it did not find the DCF files in the doctypes\dita\2.0\bookmap folder.
I copied the missing DCF files from the  dita\common\dcfmodule folder to the dita\2.0\bookmap folder.
I no longer get an error message.
Thanks.
7 REPLIES 7
Hello @DG_9924912
Hope you are doing well
You have put your query on wrong channel . This one is specific to Thingworx and your query seems to be related to another product. You can post the same to following path and one of our community member will definetly help you with proper solution.
Go to menu (on left corner)  >> SLM >> Arbortext >> Arbortext .
Alexia
(To:DG_9924912)
Hi @DG_9924912
These files can be found at :
[EditorInstall]doctypes\dita\common\dcfmodules
If this resolves the question for you please 'Accept as Solution'
Best wishes
Alexia
Alexia
Does not contain the DITA v2.0 DCFs...
I see them there.
If you don't see them there, it might be worth trying to repair your installation, or do a clean reinstall of Arbortext. When you (re)install, check to make sure any options for DITA 2.0 are selected for installation.
Alexia
(To:DG_9924912)
I also see them there in my vanilla installation.
As recommended by another User, it may be a worthwhile repairing your installation, or uninstalling and doing a fresh installation.
Do not make any changes or add any customisations and firstly check the fresh install.
I hope this helps.
Alexia
Alexia
Thanks.
Alexia
(To:DG_9924912)
Please click on 'Accept as Solution' the post where the resolution was posted.
Alexia
