PEGraphicPI Question
Finally traced down my seemingly intermittent disappearing graphic issue.
Set pegraphicpi=on solves MOST of my problems in lost graphics when composing on the PE.
What I've learned is that it does not set a pi if a graphic is not, well, called a graphic.
Is there any place I can add the other Army 40051 tags to get graphic pi's to be sent to the PE? We have icons, symbols, all sorts of graphics that simply are not called <graphic>. To make things a bit worse, the Army calls the graphic source "boardno" - I guess that makes it simpler because all graphics have that terminology with this DTD, but it is not the same terminology as Arbortext.
This is maddening. If I put all the graphics on the server, I can't reference them with the server's name (\\myserver\graphics) but have to use a drive letter (in this case J:). But to the server, J: isn't really real and gets ignored because the server is run from the main admin account (or something like that). Without the PI, just saying "fire.bmp" means too little and the graphic doesn't get found.
John T. Jarrett
BAE Systems | Arbortext version 5.4 | LOGSA XSL-FO v 1.7
