Schema/DTD Not Found Error Upon EVERY Launch?
I just installed Arbortext Editor 6.1 on a new Windows 7 machine. When I open my XML document, I get the Schema/DTD not found error [A15015]. I browse for the DTD file and associate it with my XML document. When I close the XML file, Arbortext does not remember the association, and I have to again browse for the DTD and associate it each time I open the document.
This happens whenever I close and reopen the XML document. How can I change my Editor 6.1 settings so that my XML documents will remember the association? It is currently looking for the DTD in the same root directory in which the XML document is housed, however I keep my DTD in the custom/doctypes folder in the PTC directory in Program Files.
I have checked my file location preferences and the correct file path to the DTD is listed there.
In a desperate attempt, I opened my XML document in notepad and manually entered the file path for the DTD, but I do not want to have to do this for ~2000 files. Any ideas how to make the DTD file association permanent?
