Searching for an entity
rschoen
We are running Arbortext v5.3 M010. In a particular document, I know that the entity & (an ampersand) is used multiple times. However, when I search for the entity, either from the command line using the find_entity alias or using the Find dialog window, no entities are found. I can find other entities using either method. Any suggestions on how to successfully search for the ampersand entity?
Rick Schoen
Manager, Editing/Typesetting & Application Servers, Electronic Publishing
The University of Chicago Press
1427 East 60th Street
Chicago, IL 60637
P:773.753.8022
F:773.753.3383
rschoen@press.uchicago.edu<">mailto:rschoen@press.uchicago.edu>
Don't have Editor open in front of me, but I found these in the adepters
archives. Give them a shot:
find –m –e “&.*;”
find_entity entity
The first will find ANY but if it works for you for that, maybe you can
adapt the regex.
