We have an issue where we are often left with a level 2 or 3 title and short description stuck on the bottom of a page, while the rest of the topic is on the next page.
What are my options? My thought is to create a rule that would check the room left on the page, and if the title element was within the last 3 in. of the bottom of the page it would start the topic on a new page. Is that possible?
Bryon
Hi Bryon
You're going to need to use an APP source edit to test the baseline position of the title and, if it is greater than some threshold, output a page break or set the top margin to something large to force it over to the next page.
Something like
if (formatting.currentState.yBase > new fLength("200mm") {
formatting.output(""); //For the page break or block.marginTop = "40mm" for the top margin
Put that edit in a property set and apply that to the title, then you can reuse it and it doesn't lock up your title from being styled.
Hope that helps
Simon
Hello Simon, I added the following according to your sample above
A publish throws a whole page of warnings and errors. How do I decipher the errors?
Bryon
<Record date="Mon Nov 25 10:35:22 2024" millis="1732552522"
severity="error" suppress="0">
<Level>ERROR</Level><Message>Pg 15 Javascript: ReferenceError: reference
to undefined property formatting.currentState.yBase onEnter([object
fBlock],[object Object])@stylesheet0:PropertySet:Page_Break:onEnter:1
onEnter([object fStreamPos])@stylesheet0:Element:title:title_in_procedure_in_division:onEnter:22
runMacro("sprint \"_app:spFormatWithIndex\"",true)@:0 @_app:FormatWithIndex:3
. [1500] (2:"stylesheet0:Element:title:title_in_procedure_in_division:onEnter"#105)
(1:"editorDom0"#{0;/RDStyle/ResolvedMap/techinfomap/division[1]/procedure[1]/title/#_app:Gentext})
</Message>
</Record><Record date="Mon Nov 25 10:35:22 2024" millis="1732552522"
<Level>ERROR</Level><Message>Pg 15 Javascript: stylesheet0:PropertySet:Page_Break:onEnter:1:
ReferenceError: reference to undefined property formatting.currentState.yBase
</Message>
<Level>ERROR</Level><Message>Pg 15 Block end mismatch: Trying to end
(title_in_procedure_in_division) with current nesting (techinfomap_everywhere/division_everywhere_else/procedure_first_in_its_parent_anywhere_i7A22)
[1209] (2:"stylesheet0:Element:title:title_in_procedure_in_division:onExit"#0)
(1:"editorDom0"#{0;/RDStyle/ResolvedMap/techinfomap/division[1]/procedure[1]/titlealts})
</Message>
(procedure_first_in_its_parent_anywhere_i7A22) with current nesting
(techinfomap_everywhere/division_everywhere_else) [1209] (2:"stylesheet0:Element:procedure:procedure_first_in_its_parent_anywhere_i7A22:onExit"#122)
(1:"editorDom0"#{0;/RDStyle/ResolvedMap/techinfomap/division[1]/procedure[2]})
<Level>ERROR</Level><Message>Pg 22 Table Column 1 too narrow to fit
text - skipped to next col [1200] (3:"_s_h_o_w_22_"#2861) (2:"stylesheet0:Element:image:image_everywhere_else:onEnter"#4021)
(1:"editorDom0"#{1;/RDStyle/ResolvedMap/techinfomap/division[1]/procedure[7]/procbody/procsteps[3]/procstep/procinfo/fig/#_app:Gentext/_sfe:BeforeOrAfterText/image})
</Message>
</Message>
</Record>
Hi Bryon
Sorry, I didn't get a notification that you'd had problems.
Did you try adding a big margin to the top of the block?
Simon
Finally getting back to this issue.
I made the following changes below to the original suggestion and it now stop throwing error messages, but still does not seem to work as expected. I would expect the title in image below should have moved to the top of the next page.
1 if (!formatting.currentState) {
2 formatting.currentState = {};
3 }
4 if (typeof formatting.currentState.yBase === 'undefined') {
5 formatting.currentState.yBase = new fLength("0mm");
6 }
7 if (formatting.currentState.yBase > new fLength("220mm")) {
8 formatting.output(""); // For the page break
9 block.marginTop = "10mm"; // For the top margin
10 }
Bryon
Hi Bryon
I just noticed a syntax error in the original code I sent you - it needed an extra closing parenthesis after the condition of the if statement. Also, the property is 'ybase' rather than 'yBase'. That's probably where the errors were being generated...
if (formatting.currentState.ybase > new fLength("200mm")) {
There are some naughty things in your version - formatting.currentState is set by the APP formatting engine, so you really shouldn't be redefining that!
Hope this helps
Simon
Thanks for the help Simon, Just so I understand what the script is doing. It is looking for an element in the bottom 200mm (4in) of a page. Is this from the bottom of the physical page or from the top of the footer? If it finds one, it inserts a page break, then moves the element to the next page.
I have changed it back to what you had suggested. I have added the property set to all three levels of titles, but when publishing I got an error with this change something about a block end mismatch What does this mean
<Record date="Thu Apr 17 08:43:37 2025" millis="1744897417"
<Level>ERROR</Level><Message>Pg 368 Javascript: TypeError: arguments[0].source
is null onEnter([object fStreamPos])@stylesheet0:Element:title:title_in_procedure_in_procedure_in_division:onEnter:28
. [1500] (2:"stylesheet0:Element:title:title_in_procedure_in_procedure_in_division:onEnter"#155)
(1:"editorDom0"#{0;/RDStyle/ResolvedMap/techinfomap/division[11]/procedure[1]/procedure[3]/title/#_app:Gentext})
</Message>
</Record><Record date="Thu Apr 17 08:43:37 2025" millis="1744897417"
<Level>ERROR</Level><Message>Pg 368 Javascript: stylesheet0:Element:title:title_in_procedure_in_procedure_in_division:onEnter:28:
TypeError: arguments[0].source is null . [1500] (2:"stylesheet0:Element:title:title_in_procedure_in_procedure_in_division:onEnter"#155)
</Message>
<Level>ERROR</Level><Message>Pg 368 Block end mismatch: Trying to
end (title_in_procedure_in_procedure_in_division) with current nesting
(techinfomap_everywhere/division_everywhere_else/procedure_first_in_its_parent_anywhere_i7A22/procedure_everywhere_else)
[1209] (2:"stylesheet0:Element:title:title_in_procedure_in_procedure_in_division:onExit"#0)
(1:"editorDom0"#{0;/RDStyle/ResolvedMap/techinfomap/division[11]/procedure[1]/procedure[3]/titlealts})
</Message>
</Message>
</Message>
</Message>
</Record>
Bryon
I have been modifying the fLength dimension and I don;t think it is working correct yet.
Bryon
