Hi All,
Here is your Wednesday mission if you should agree to accept it!
So, at publish time if I apply the profile IPLtype=user then the text "NSS" is output
if I apply the profile IPLtype=engineering then the text "3051-25" is output
All good so far...
However for some parts in the "user" context I want to output "3051-25", how do I do that?
Note: the content between the <part_reuse> tag is inserted from a repository and I don't want that touched as it will be used in other documents.
<part>
<pos>1</pos>
<part_reuse>
<partnumber><label ipltype="engineering">3051-25</label><label ipltype="user">NSS</label></partnumber><partname_en>Pan bar
unit assay.</partname_en><comment></comment>
</part_reuse>
<serial_no></serial_no>
<kit_no></kit_no>
<quantity></quantity>
<unit></unit>
</part>
Is this something that Styler can handle?
We're looking at all possibilities at the moment.
Cheers
Pete
