Update gentext locally?
ClayHelberg
18-Opal
Hi Adepters--
Does anyone know of a way to update the gentext just for a single
element in a document? For example, after some code makes a change to an
attribute value, I would like the gentext for the element to be updated
to reflect the change in the editor view--but I don't want to do a
global refresh for the entire document (which can take a long time) just
to pick up that one change. I'm looking for something like this, in the
case where the gentext includes some attribute value:
function update_element(oid, attrname, attrval) {
# update the OID
oid_modify_attr(oid, attrname, attrval);
# refresh the OID's gentext to pick up the change
oid_update_gentext(oid);
I'm trying to either discover a built-in function to do the job of
"oid_update_gentext(oid)", or write one of my own, but so far haven't
had any luck. Has anyone been able to do this? Thanks.
--Clay
Clay Helberg
Senior Consultant
TerraXML
Try show fullkeymap. I thought there was a alt or ctrl key command that
updated only what was visible in the Edit window. Not sure if you can
hijack that (if I'm even remembering correctly) but maybe ...
Thanks Paul, but the only entry I find there is Alt+Ctrl+g =
ShowGentext, which updates the whole document.
--C
Clay Helberg
Senior Consultant
TerraXML
