Is there a way to create custom line styles? I need to generate a box in which the line style is a gray bit pattern. The pattern I'm seeking is similar to the 15% gray in the pattern section of the fill window. I already have the box (using the rectangles tool) and have set the correct line width. I just can't seem to be able to customize the dot pattern.
Hello!
Ken Hurst wrote:
...Is there a way to create custom line styles? ...
1. Close all active documents in a window. Then go to "Edit" -> "Preferences" -> "Attributes" -> "Styles":
2. In active document. Go to "Window" -> "Show attribute window" -> "Styles" -> "New style":
P.S. What version of Arbortext IsoDraw are you using?
I'm using version 7.01
The screenshots (above) were created in version 7.1.
