Good day All,
I've created animations using Isodraw cadprocess. Is it possible to play the animation in Isodraw itself or it is mandatory to have ISOVIEW?
Thanks for your cooperation.
Yes, IsoView is really the target application for the animations.
However it is possible to preview them in IsoDraw: In the Timelinie
window, click somewhere at the start of you animaiton while you hold the
Ctrl key pressed. When you release the Ctrl key the animation will stop
at the next full second. Please note that the preview does not play with
the same exact speed as the resulting animation in IsoView.
