oid_modify_attr() issue
<h3>I've been having some problems with the oid_modify_attr() acl command, I readed th acl reference and I was using the commando without any problem, however I suddenly note something strange; I saw that arbortext changes the attribute of my sections in my opened Document only when I modify the content of the section, more specifically when I remove the section, make some changes in its content and then I re-insert the modified section into my document again, only in those cases the editor makes the change of the seciton's attribute; I'm needing to change the attribute in other escenarios because I want to navigate through the sections of my docbooks and I would like to assign an attribute to every section which works as a flag to understand if my section was visited, modified or if the section is the last section where the user is situated at the time he decides to close the document maybe for restart the navigation later.
Again I appreciate your time and the information you kindly provide me.
Paulette
