I want to publish my pdf document that I made from AE but the bookmarks does not show up. How do I solve this?
If you are using a .style file to style your document, then in your TOC definition do you have the check box for bookmarks checked (Use for PDF bookmarks)?
Yes I have that checked but it still won't show up the bookmarks.
I haven't created bookmarks in Styler, but I saw in another thread that you must have an element designated as Document and you must use File->Compose->PDF
Is the TOC with the bookmarks check box checked being used by the document?
In your PDF viewer are Bookmarks hidden?
Select the menu pick View > Show/Hide > Navigation Panes > Bookmarks
