svg export in IsoDraw faulty
mschnurbus
8-Gravel
Hello!
Most recently, I used Isodraw 7.3 in the M040 build 6. An svgz export has worked flawlessly in this version. Now my system was changed to Windows 10 and with this came an Isodraw update to M080 build 6. Since this svgz export does not work correctly anymore. Hotspots created in Isodraw are displayed twice in the svgz, which means that the online spare parts catalog can no longer display the correct item numbers!Smiley Sad
I attached screenshots to this problem in a Word document.
About help and solution suggestions, I would be very grateful!: smileyvery-happy:
Best regards Mirko
Not sure if this is the same issue, but do you also use editor? We had an issue with exporting svgs from IsoDraw where IsoDraw would duplicate the text in the callout. See SPR 7471102. They fixed it in 7.1 M21.
Information from the support call:
<g class="callout callout_A">
   <g>
    <line stroke="#FFFFFF" stroke-width="1.14" x1="43.085" y1="32.926" x2="25.675" y2="39.988"/>
    <line stroke-width="0.38" x1="43.789" y1="32.64" x2="24.972" y2="40.274"/>
   </g>
   <path stroke-width="0.38" fill="#FFFFFF" d="M22.431 40.274C22.431 41.676 23.568 42.814 24.972 42.814 26.375 42.814 27.512 41.676 27.512 40.274 27.512 38.871 26.375 37.734 24.972 37.734 23.568 37.734 22.431 38.871 22.431 40.274 22.431 40.274 22.431 40.274 22.431 40.274L22.431 40.274z"/>
   <text x="23.698" y="41.536" stroke="none" fill="#000000" font-family="'Arial'" font-size="3.528" font-weight="bold"><desc>A</desc>A</text>
  </g>
Note the bold text.
<desc>A</desc>
is supposed to be a "comment"/description. However, the composition engine appears to be printing it. I have asked my associates in R&D about it.
I found that if I delete <desc>A</desc> from the file, then I get the desired results.
I also found that if I move <desc>A</desc> to be outside of the <text> element (after the </text> tag), then I get the desired results.
Bryon
Hello Bryon!
It works in 7.3 M060, in newer versions not! I think that the error is in the SVG filter.
