In Footer . I am Not able to Reduce the Table Height. Is there any way reduce the default row height.
K.K
Hi Sridhar,
Could you provide the Community a bit of specifics on your situation?
You mention footer, so this is in the stylesheet, right? Are you using FOSI or Styler?
Have you inserted a table in the footer section, and are trying to modify it?
Perhaps a screenshot of the footer section as currently defined might help.
Rafael
