table insert error: a30308 table is structurally invalid (it's missing <title>)
naglists
Hiya,
I have a secondary Edit Window with a somewhat modified environment in which
table inserts fail with the following error:
INTERNAL ERROR: file ../src/tmtag.cpp, line 266: Context check failed
[A30308] table is structurally invalid. <tgroup> is out of context.
Table insert using the quick list work fine in the parent Edit Window. We
are using 5.3 m110. CALS table model. I have checked Help > About Arbortext
Editor > Session and the only differences on the Session or Document tab are
"Document" on the Document tab, which is blank in the secondary window and
"Cache directory" on the Document tab which does not exist in the secondary
window. If I try this in a new document that has not been saved but is the
"main" Edit Window, it looks the same in the Document tab (no value for
Document, no line item for Cache directory) AND the insert table works as
expected.
If I turn off context checking in the secondary window, the table insert
succeeds but the markup is missing <title></title> between <table> and
<tgroup>.
Can't find tmtag.cpp anywhere in the install directory.
Has anyone found instances where table insertion fails due to lack of a
title?
Weird.
Paul Nagai
0 REPLIES 0
