The problem I am having is the mainbooktitle does show the tm element when publsihing to pdf. We had a style sheet created for us. They add the text to the cover using a _ufe with a x-path reference (/RDStyle/ResolvedMap/servicemanualmap/booktitle/mainbooktitle) in it. My limited understanding of this is that it is going to publish whatever is seen in the mainbooktitle element. So I should also expect that the tm element should also be displayed?
any help would be great
Bryon
Hmm my manual title has this line in it. By the xpathstring expr, I take it that this is a a xpath string.
<_gte:XPathString expr="/RDStyle/ResolvedMap/servicemanualmap/*[name()='bookmeta' or name()='servicemanualmeta']/modelno"/><_dtd:_newline/><_gte:XPathString expr="/RDStyle/ResolvedMap/servicemanualmap/booktitle/mainbooktitle"/>
I went into the _ufe and copied the path then went to insert element Content, by xpath and pasted (/RDStyle/ResolvedMap/servicemanualmap/booktitle/mainbooktitle)into the Xpath expression. It now behaves as it should. Is there any reason why you would not want a xpath to pass on child elements?
Thank you Clay.
Bryon
