Is there a way to use a tiv out of its scope? I tried to do a LEP for the entire document by using the Chapter LEPs, which uses a tiv scoped to chapter. Even if I save the tiv to a tdv, it still gets flagged as out of scope. I was wondering if there was a way to save a tiv (or "freeze" the contents) to another variable so the scope would be irrelevant. If I delete the scope, the chapter LEPs don't work correctly, and I haven't figured out how to force a reset on the tiv.
Thank you all for your useful responses! Ed, each "chunk" has its own LEP, and then there is a LEP for the entire document which lists each chapter chunk. Anyway, now I have more things to try, because I cheated and just hardcoded most of it.
