usedistiller switch
Hi folks,
I'm using Arbortext PE 5.4 with a FOSI. I have a publish job that needs to use DirectPDF to add custom PDF metadata including document properties and bookmarks, which is not possible using Adobe Distiller. Can I dynamically switch the usedistiller=off from usedistiller=on without a Tomcat/services restart to register the change? Is there a way to support Distiller and DirectPDF configuration on the same PE server? If not, the obvious choice is to move away from Distiller. But are there any benefits to using Distiller instead of DirectPDF? The reasons we use Distiller is unknown to me.
Thanks in advance,
Bryan
