Isoview disable scroll wheel
calvin.l
7-Bedrock
Is it possible to disable the scroll wheel functionality in Isodraw, so if the user uses the scroll wheel the graphic won't zoom in/out.
But I would still like to maintain the zoom functionality via selecting the zoom tool.
5 REPLIES 5
VladimirN
(To:calvin.l)
Hello!
calvin.l wrote:
Is it possible to disable the scroll wheel functionality in Isodraw...
Do you want to disable this feature in IsoView or IsoDraw (theme topic: "Isoview disable scroll wheel")?
Sorry for the mix up.
I'd like to disable the scroll wheel in Isoview.
VladimirN
(To:calvin.l)
Below are attached files "Arbortext IsoView Programmer's Reference" (for version IsoView 7.2) and "Arbortext IsoView Functional Reference" (for IsoView 7.0) in PDF. Hopefully, these reference documents will be helpful.
Unfortunately I couldn't find anything in the API in regards to the scroll wheel. It doesn't register as a click so I can't tell Isoview to disregard it.
The closest i could think of was disabling the zoom or limiting the zoom, but i don't want to do that. And even when I did try it... it didn't work.
Do you know anything else that might work?
VladimirN
(To:calvin.l)
You can create a new "Case" with this question to technical support PTC (if you have an active maintenance): http://www.ptc.com/appserver/cs/case/case_logger.jsp
