using arial unicode ms characters in my FOSI
6 REPLIES 6
What has worked for me is using a charent.cf file in the custom/lib directory. The file only needs to contain the characters you want to re-map, as follows:
#Description: This file contains character mappings for specific character entities
# that don't have glyphs in the regular Codes fonts. See the main
# charent.cf file in the 'lib' directory of the Arbortext Editor
# installation tree for an explanation of how this file works
accents: # ENTITIES IN THIS SECTION ARE OF TYPE "accent"
windowsonly:
macr - - unicode 0x2C9 =
endwindowsonly:
chars: # THE REMAINDER OF THE ENTITIES IN THE FILE ARE OF TYPE "char"
puncsp - - unicode 0x2008 current "\hmode\kern.2em|"
windowsonly:
check "Arial Unicode MS" 0x2713 unicode 0x2713 "Arial Unicode MS" 0x2713
endwindowsonly:
I don't need to put any special character handling in the FOSI.
Would this perhaps work for you?
David
David S. Taylor
Project Manager, Production and Marketing
Codes and Evaluations | NRC Construction Portfolio
National Research Council Canada
Building M-23A, Room 239 | 1200 Montreal Road | Ottawa, ON | K1A 0R6
Telephone: +1.613.990.2731 | Fax: +1.613.952.4040
David.S.Taylor@nrc-cnrc.gc.ca<">mailto:David.S.Taylor@nrc-cnrc.gc.ca>
Thanks, David,
We abandoned the charent.cf file a long time ago because it was not
foolproof. I do not know if it has since been fixed, but there was a time
when Arbortext could not guarantee that the charent.cf file would "fire"
only at the end of the content pipeline just before applying the print
stylesheet ... when it fired prematurely, the character mapping did not
necessarily survive subsequent parsings resulting in unpredictable final
output.
I'll keep this option in mind though ... if nothing else works (and we
can't convince our authors to accept similar but not identical glyphs), I
may have to give that another try.
On Tue, Jul 31, 2012 at 6:17 AM, Taylor, David S. <
> re-map, as follows:****
> character entities ****
> the main****
> Arbortext Editor****
> works****
> accents: # ENTITIES IN THIS SECTION ARE OF TYPE "accent"****
> windowsonly:****
> macr - - unicode 0x2C9 =****
> endwindowsonly:****
> chars: # THE REMAINDER OF THE ENTITIES IN THE FILE ARE OF TYPE "char"**
> puncsp - - unicode 0x2008 current "\hmode\kern.2em|"***
> windowsonly:****
> MS" 0x2713****
> endwindowsonly:****
> I don't need to put any special character handling in the FOSI. ****
> Would this perhaps work for you?****
> David****
> *David S. Taylor*
> *Project Manager, *Production and Marketing
> Codes and Evaluations | *NRC Construction Portfolio*
> Building M-23A, Room 239 | 1200 Montreal Road | Ottawa, ON | K1A 0R6****
> David.S.Taylor@nrc-cnrc.gc.ca****
> *From:* Paul Nagai [
> problem in my FOSI. I am currently trying to replace two characters I
> previously pulled from a Zapf Dingbats BT font with characters from Arial
> Unicode MS. The arrow and shadowed square above. Nothing displays.
> I can get close on the square:
> Unicode Character 'WHITE SQUARE' (U+25A1)
> <charsubset charsubsetref="zapf">
> <usetext source="\&amp;x10132;\" placemnt="before">
> <subchars charsubsetref="arialms">
> </subchars>
> </att>
> Any thoughts?
> Paul Nagai****
Hi Paul,
I've been using the charent.cf file for about 2 years now (AE 5.2 m130 and 5.4 m080) and it has been working well. I don't know if there was a problem prior to those releases. It did take a while to fully understand how it's supposed to work, some experimentation was needed.
Most character rendering problems we have now can be traced back to content that authors cut and pasted into AE, bringing in incorrect or non-standard character codes from the original document application.
Cheers,
David
Do know if you use anything that forces a trip through the content
pipeline? (Profiling and Dynamic Link Manager (DLM) are examples)?
On Tue, Jul 31, 2012 at 11:39 AM, Taylor, David S. <
> Hi Paul,****
> how it's supposed to work, some experimentation was needed.****
> non-standard character codes from the original document application.****
> Cheers,****
> David****
> output.
> I'll keep this option in mind though ... if nothing else works (and w...
> </subchars>
> </att>
> Any thoughts?
> Paul Nagai****
We don't use either of those. Also we are using Print Composer for composition to Postscript or PDF in most cases.
David
