xml catalogs
jsulak
xml catalogs
Hi Adepters,
Here's an easy question to start the day off: In addition to "plain text" XML catalogs, does Arbortext support catalogs with the XML syntax (
I looked into it a while back too, and came up empty handed. =/
-G
I beleive the answer is no. Arbortext caalogs pre-date and maybe were the
inspiration for the OASIS effort.
My guess is you are trying to "maintain" one catalog file for all your
applications. Don't think this will be possible, but you ould run a
stylesheet or program against the XML catalog format and generate the
Arbortext version. Then all you have to do is to remember to run the
conversion step if you make an update.
For the definitive answer on if they are supported, log a support call and
let us knw what they say.
..dan
> -G
