In this episode the definition of the powerful feature "Automatic UDF's" will be shown. With this technique you are able to give your parts a certain intelligence. The parts will then create their needed mounting holes with just a push of a button.
The 2nd topic of the video is the definition of screw connections. With this functionality you can easily add screw conncections to your assembly.
