I've looked through the community and the internet and haven't found anything on this subject, so hopefully I didn't just miss it somewhere. I have an assembly that someone created an exploded view for, so I don't want to just delete it. But every time I open the assembly, the default view is the exploded view and the first thing I have to do to get any work done is unexplode the model. I've looked through the view manager and the config settings and I can't find any means of changing this default setting. How do I get the assembly to stop doing this?
In the view manager, RMB on the DEFAULT EXPLODE name and then at the bottom of the RMB menu, there is a toggle EXPLODE, it's likely checked on your model, uncheck and save your model.
