Controlling dimensions of parts present in an assembly using excel sheet
ptc-5346276
Hello
I am using Wildfire4.0, I have a situation where I need to control the dimensions of parts present in an assembly using excel sheet.
If I change the value in the excel sheet and regenerate the assembly, all the parts present should be updated to the value entered.
Can you please suggest how to do it?
Thank you.
1 ACCEPTED SOLUTION
This is documented in the Creo help system, look for Excel analysis
YES!  It is most definitely possible.  Simplified Logic Inc specializes in bi-directional Excel to Creo or Creo to Excell data transfer this with an application called Nitro-CELL.  Please see this Website: Simplified Logic, Inc. and YouTube Channel:  Simplified Logic, Inc. - YouTube
