Creating a new part from a mold?
amendicino
Hello there, I've been using the student edition for about a month and I am pretty new to the software.
I found out how to make a "mold" in assembly mode if you already have the part (Model > Component > Component Operations > Cut Out)
But what if I need to go through the opposite process? I have the mold and I need to create a new part out of it.
Any help? Thank you.
1 ACCEPTED SOLUTION
Welcome to the forum, Andrea.
You could subtract the mold from a block in a part the same way, but I suggest you find the master part and copy that to make a new part. Somewhere the cut-out part should exist.
I don't know how I managed not to think of that. I was so busy searching for some command I didn't even need.
Thank you!
