Creting a shrinkwrap of a framework created assembly
BenLoosli
23-Emerald II
We are using Framework extension to create a building frame using steel structures and then adding some piping  work files to the frame. We now need to create a shrink-wrap of the assembly to use as a background for some additional component placement.
The designers are having u=issues with generating a good shrink-wrap that can be imported into another assembly and use it to dimension these additional components to. Is there a trick to using shrink-wraps with framework created parts?
Creo 4 m080 with Windchill 11.0 mo030 CPS 16
why designers do not use STEP export/import ?
Martin Hanák
How are you creating the SW ?
I just tried it with below staircase with good result.
