I have found in Creo 2.0 that when assembling parts it often defaults to NORMAL constraint when selection two planes or axes instead of COINCIDE. 99% of the time i want the default constraint to be COINCIDE. It is annoying to constantly go to the drop down and change the constraint from NORMAL to COINCIDE. Is there a way to set the default constraint to COINCIDE so that when i select two features (plane, axis, point, surface) when assembling that I can have the COINCIDE constraint applied to them automatically and not NORMAL.
If anyone has any experience with this your help would be greatly appreciated.
Try setting the following config options:
auto_constr_always_use_offset NEVER
comp_angle_offset_eps 91
comp_normal_offset_eps -1
-Roger
