I have a NC assembly. It contains 2 components that are auto-nested.
There are 2 nc sequences, 1 for each.
I can write in Pro/PROGRAM an if-then statement to remove the second NC sequence based on a yes/no parameter in the first part.
However, how do I then remove the 2nd component which I just removed the nc sequence?
It's likely I could do this in a "PROGRAM" for the .asm file, but it appears that in NC_SHEETMETAL you can only define the program for the .prt where the MFG info is stored.
Using WF5
