Is it possible to calculate weld volume by using weld application in creo?
If yes pls give weld volume calculation procedure in creo.......... I have tried to calculate the weld volume by using of the weld application.
i faced some issue because i have created weld then i have to enter the x section area value for each welds (In my assembly more then 100 weld feature is there). i am doing rework for all welds it will take more then a day.
