I would like to request to PTC please update your software so that it would be ease to operate to user. I worked on Solid edge and Solidworks previously. What interesting thing I found it is far better to work on Solidworks as compared to Creo. I listed below my observations:
1. In Solidworks part in assembly showing its degrees of freedom unless it is constrained (that is an advantage so that we can see how it moves with given constraint)
2. I am unable to select parts only to view in an assembly.
3. Difficulty in measuring a distance or any entity with measuring tool. (it is more smart in solidworks).
Creo provides a large number of ways to affect component visibility in assemblies. Can you explain more about the second item on the list?
