Photo-Realistic Rendering in Creo 4.0 F000 is not starting
rsobecki
Hi!
does anyone successfully run Photo-Realistic Rendering in Creo 4.0 F000???
When I press at button PR_Button.PNG no action happen???
I tried with both advance renderer licenses I got and no positive results - only license visible consumption ;-(
is this a bug in this first F000 release of Creo 4.0?
The Photo-Realistic Rendering requires the Advanced Render III license.  This is a known issue and Tech Support has filed SPR 6327272 against the lack of a missing license message when attempting to access this function.
Refer to article CS253200 for additional information.  If you are unable to access the article, please first create an account here.
StephenW
(To:rsobecki)
There was a long discussion here Re: Creo 4 Photo-Real Rendering - Anyone Try yet?
Maybe a license update is needed.
rsobecki
(To:StephenW)
Thanks for your feedback - we'll investigate and check if license update will help!
rsobecki
(To:AmitDeshpande)
You are right - I can confirm this - thanks!
only pity is if I'm accessing my machine using remote desktop, Creo crash when I click at Photo-Realistic Rendering
Perhaps it is because as I'm guessing hardware accelertion is set to off or something...
