'Placement' sub menu won't appear - what have I missed?
msingleton
1-Newbie
Hi all,
I am working on Creo 3 with various assemblies and sub-assemblies. Until recently it was functioning normally, but now when placing an object/assembly, the sub menu under the 'Placement' tab won't appear. The adjacent Move/Options/Flexibility/Properties tabs work fine, its just the Placement.
Hopefully one of you guys can help with the problem.
10 REPLIES 10
Hi Mike,
I feel as if I've come across this issue before, for a different customer, but I am unable to locate it.
  1. Have you tested on another machine?
  2. Is this for all assemblies or just some?
  3. Has Creo been running for a long period of time, without a restart?  If so, close down Creo and launch it.
  4. Test without any configs.
If I can find that other case, I will add additional notes here.
Amit
Hi Amit,
I haven't tested on another machine, as well. I don't have one to test. It's the same for all assemblies, and also whether Creo has been running for hours or just started. I am running it without any configs loaded up.
Thanks for your help,
Mike.
It looks like you are using mechanism connections which are handled differently than placement.
I see the message "Connection Definition Complete," which is part of mechanism, not assembly placement, which is why only Move is available in order to let you drag the mechanism.
I don't know how you got there, but that seems to be where you are and it is acting as I would expect it to act.
see Re: Placement disapperaed
MH
Martin Hanák
Beautiful.
The last post in that thread;
"In such cases other option can be used to rest the position of panels. Option "Rest Panels Position" is available under File > Options > Window Settings "Rest Panels Position" "
Got things sorted straight away.
Thanks for the help everyone. I can resume as normal!
gmehta
(To:msingleton)
This work...
"In such cases other option can be used to rest the position of panels. Option "Rest Panels Position" is available under File > Options > Window Settings "Rest Panels Position" .
Thanks.
PTC should make an article about this fix and put it  in the Technical Support Search section
@msingleton  yes, its  really working. thanks.
Why would PTC have the capability to do this?
It's rhetorical.
cracusen
(To:MartinHanak)
MH,
My users would like to deactivate this Creo 3.0 "feature" entirely. Can this option be set in config.pro?
-Chris
I am sorry I do not know any option how to disable this behavior.
MH
Martin Hanák
