Rigid vs. Weld connection
VladimirPalffy
In this tutorial, you can learn the differences between Rigid connection and Weld connection.
Note: Adding a rigid connection to a second component of the sub-assembly has eliminated the motion - these surfaces cannot be coincident. To assemble this sub-assembly and maintain its motion - the Weld connection set should be used.
Best Regards,
Vladimir Palffy
0 REPLIES 0
