Hello!
Anybody know the purpose of the file ...\Common Files\afx\configuration\efx_standard_drawing_list.txt ??
How to use this file?
Hi Yaroslav Sinitsyn,
The file defines AFX library names that will have a standard drawing. If not defined in the list and a drawing exists in the library, this drawing will be copied.
Example:
A square_beam.prt and square_beam.drw are in the library. If the square_beam is defined in the efx_standard_drawing_list.txt AFX will create a NEW drawing as defined in the drawing_setup.txt in the library.
If NOT defined in the efx_standard_drawing_list.txt the square_beam.drw will be copied. This also means, that the drawing_setup.txt will have no effect!
greetings Sam
How will be work the option COPY_STANDARD_DRAWINGS_FROM_LIBRARY in conjunction with this file?
For example:
Expected: If NOT defined in the efx_standard_drawing_list.txt the square_beam.drw will be copied.
But the value of an option is NO
!Copy AFX standard drawing from library when assembling AFX component.
COPY_STANDARD_DRAWINGS_FROM_LIBRARY NO
In this case the drawing not will be copied and not will be created NEW?
I made a flowchart to show the behaviour. I hope that makes it clear
Greetings Sam
