part, how to set color in 1 click, in CREO 3.0?
AntoniodeItaVen
Hello world,
Just a simple question.
for some reason in CREO 3.0 M010, when I try to set a color for a part it sets the color surface by surface, I have tried by selecting the part on the three but it does nothing.
In an assembly yes, it sets the color for the part selected but in a part file it only does that for the surface selected which is a pain, in Creo 2.0 I think it was posible.
does anyone knows what I am doing wrong?
Antonio,
You may add some information about fixing this and mark appropriate reply as correct answer for the post.
rmb, select by list
in the list, select the part
You can try selecting the part name in model tree to select the part.
mm I remind I tried it but did not work...
anyway I tried it again and did work
thanks
Antonio,
