pcb conversion
pfadams
pcb conversion
I remember converting P-CAD designed pc boards using pro 2001 and we were able to extrude all the components at the same time. My question is can we still do this with CREO Elements (m090).
How do we do it if possible. I've tried but with little success. I have only been able to bring up the board outline and the mounting holes. I want to use the final product for assembly drawings.
Thanx
You need to the two file types from you ecad system the emn and the emp . The emn gives you the board info and the emp gives you the info for placing parts. If a part name matches a proe part it will put it into location and you will have a full 3D pcb. You can also check out
