Automate Creation of Suspected Link when updating Custom Fields
MeganB_T
8-Gravel
Is there a setting or field within the tracker settings that will propagate a suspect link to the downstream item when a custom field in the upstream item is changed?  The suspect flag in my project only appears when the description of the upstream item is edited.
First thing to check is the “Omit Suspected when changing” property of the field.
If you want changes in this field to trigger suspect, this property should not be set.
Hello @MeganB_T
It looks like you have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
