Codebeamer: Customizing Filename in an Excel Export.
CG_10919031
3-Newcomer
Software: Codebeamer 2.1 (training environment)
Datecode: 2.1.0.0
Hello all,
I am exporting a work item in excel format from a tracker and the exported filename is in the format "[project name]-[tracker name]", I want to customize it to be "[project name]-[tracker name]-[work item name]". (attached a picture for reference).
I have checked and tried customizing the export template, but I am only able to customize the content of the export file, not the filename.
Let me know if this use case is possible. And if yes, please guide me on where I can find the configurations to customize the exported file's name.
Thank you
At this time it is not possible to control the format of the exported filename. To request this feature, please post the request to the Codebeamer Ideas board where you and others can add comments and vote on suggested changes.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
