Create a 'Specified Date & Time Range' logs option in the 'System Admin/Server Status dashboard'
RK_8650
11-Garnet
Hello Team,
Good day!
 As of now, in our System Admin/Server Status dashboard under the Download Logs option, only "Export Daily Logs" and "Export Weekly Logs" are available. There is no option to select a 'Specified Date & Time Range'. If implement this option, we will be able to export logs for any specified date and time range.
FYR, a screenshot is attached.
Thank you in advance!
Best Regards,
Raj Kumar
Hello Raj,
This is correct - the Server Status dashboard allows for exporting logs on a daily, weekly, or all logs basis and there is no option to specify a custom timeframe. Please post this enhancement request to the Codebeamer Ideas page to request the feature and give any additional comments for your use case:
https://community.ptc.com/t5/Codebeamer-Ideas/idb-p/codebeamerideas
Thank you.
Hello Raj,
Thank you.
Hello Joe,
Thanks for your information.
Raj Kumar
