CodeBeamer 21.09
We have a tracker whose structure is referenced by more than 50 trackers, each in a different project.
The trackers have a choiceField which is based on (currently 5) options.
The task is to modify this field to reference a CMDB instead of the options. The new CMDB will contain an entry for each option.
How to migrate the data in the items (options->CMDB ref)?
Mass edit would be okay (filter for each option and set the reference), but there are too many trackers (that would be > 50*5= 250 mass edits),
Is there something to change them more efficient?
Hi @Labisch
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
