Fields order and grouping inside a Codebeamer tracker
GT_10907124
Hello!
We use a large number of fields within our requirement trackers. Since we are always adding more and more fields, I was wondering if there is a way to divide the existing fields in a certain way? For example by groups. So that the end users will have a better way to look at the fields. And so the order and meaning of the fields will be clearer and understandable then the current interface.
From the Codebeamer "Issue View", the tracker has already several sections such as tracking sections, description sections and details sections. Each section has a line separator, if we could have something like this in the editable fields section that would be great for me!
Does anyone know if it is possible to do something like this? or similar?  Any advise would be appreciated!
GVajda
(To:GT_10907124)
unfortunately you cannot create new separate sections for fields.
All your new custom fields will be in the same section, but you can define the field order with drag and drop in tracker configuration field tab.
I hope it helps!
GVajda
(To:GT_10907124)
I hope it helps!
Hello @GT_10907124,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
