Is anyone faces Codebeamer performance issues ? How you fixed it ?
Performance issue could be affected by many facts, like database, network, hardware spec etc, so the issue has to be investigate case by case.
Would you please post a support case to provide the details about your issue?
I m looking for known performance issues with Codebeamer , which help us during implementations at client
Hi SJ_10744473,
Since you have no specifical issue, I suggest to start from check the wiki about Post-installation Configuration and API Throttling settings.
https://codebeamer.com/cb/wiki/8737
https://codebeamer.com/cb/wiki/17380873
I also suggest to open an case to track this if you have further questions, since I think the performance tuning issue is a big and complex topic. It is on ground of lots of facts, like the number of login users / data size / requests / network bandwidth etc.
Hi, @SJ_10744473
Did you resolve your issue? Did @IvyZhuang suggestion help you?
Please let us know so your outcome with help other community members with a similar issue.
Thank You!
Jaime Lee
Yet to get related good information. I m looking for the codebeamer known issue ( may be in previous or latest release) and resolution for same. I did not find such KBA on support portal.
Thank you !
Shripad
