I'm looking for an option how I can consume child computed field value in the parents field. Means I'm looking for the recursion - I need to use Aggregation rule in computation field which is not possible ootb - as soon you define "Computed as" for the field, the Aggregation rule (sum/total) gets deactivated.
My use case: I need the information available here in screenshot in a separate tracker field, to reuse it for another use case.:
The problem is, I can calculate children of a parent by using "Computed as = length(children)" but it counts 1st level children only. Therefore I thought I can work with Aggregation rule, but it is not possible for fields where "Computed as" is defined. Any ideas how I could solve that problem. Thank you!
Solved by using following computation in "Computed as" for my customField[1]:
length(children)+sum(children.{child|child.customField[1]})
Hi @Alexej_L
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
